  3. Error in layout extraction
  • Views 15788
amnaggar
amnaggar over 7 years ago
Hi, I am trying to check the DRC for my layout design, when I run DRC I got this error with the following message:
sh: -c: line 0: syntax error near unexpected token `('
sh: -c: line 0: `cp /tmp/CDS_ENVF77zvv /{Path}/.cdsenv'
Also, I can't find the file ".cdsenv" in the provided path.?!
Thanks in advance!
    Andrew Beckett over 7 years ago +1
    This is a Mentor tool that you’re using, so asking a question in a Cadence forum is not the best place to ask. I would suggest either a Mentor forum or Mentor customer support. Regards, Andrew
  • amnaggar
    amnaggar over 7 years ago in reply to Andrew Beckett
    Thanks Andrew, I already sent to them but I didn't get the reply yet. I will check Mentor forum.
