  3. Voltus-Fi Peak static current analysis treatment of decoupling...
  • Views 15366
Voltus-Fi Peak static current analysis treatment of decoupling caps and inactive devices
hchan
hchan over 7 years ago
I have a couple of questions regarding how Voltus-FI static IR-drop analysis:
1. How does it treat decoupling caps and dummy or inactive transistors (Pmos with VDD-connected gates, Nmos with grounded gates, etc) in the design? Would it regard it as ideal open circuits with 0A current going through them, or not?
2. In IR-drop power rail analysis, we are aware that users can specify static current values for nets in the static current input file, but is there a way to specify the *ratio* of currents branching into 2 or more blocks devices?
In the Voltus-FI user manual, there is a description of the Average Static Current Analysis using the switching activity information of signal nets, and Net based average power to specify different power values for different nets. If this is the approach to take, can this method be configured through ADE Assembler GUI?
Henry
    Hi Henry,
    Please contact customer support.
