  3. hierarchy info for each fet in the design
  • Views 14902
SatendraMaurya
SatendraMaurya over 7 years ago
I need ful hierarchy for all the fet in the design. A flat netlist is the easiest way to go but spectre does not has a way to get any flat netlist. So the only option is to get it from some SKILL code. Does anyone has a handy skill code that give all the hirarchy listing for all the fets .
    Andrew Beckett over 7 years ago +1
    It's not that clear what you mean by "ful hierarchy". If all you need is a flat netlist, then you could use the CDL netlister by putting: cdlNetlistType='fnl into your ~/.simrc file (could be working…
    cdlNetlistType='fnl
    into your ~/.simrc file (could be working dir too) and then using File->Export->CDL.
