  3. error in checking lvs test with calibre tool in cadence...
  • Views 14750
error in checking lvs test with calibre tool in cadence ic
davidspen
davidspen over 7 years ago
hi i'm trying to apply lvs test to the layout of my circuit that is a transimpedance amplifier which uses 4 spiral inductors .the problem is when i try to check lvs it gives me the following errors :
no matching ".SUBCKT" statement for "SPIRAL_STD"
source can not be read
what should i do to solve this ?
thanks in advance.
    Calibre is a tool from Mentor, not Cadence. So you'd be far better off asking this in a Mentor forum or to Mentor customer support...
