  3. NPORT file path
  • Views 18952
NPORT file path
armenhr
armenhr over 7 years ago
Dear Community,
I wonder if I can set the S-parameter data file path parameter in the schematic as variable and sweep it among discrete values.
Sample scenario: Some data link has an input power dependent characteristics which are modelled 1mm.s3p 2mm.s3p 3mm.s3p, which corresponds to 15 12 and 9 dBm of input power.
I want to do a parametric sweep grouping this two parameters. Anyway, cadence does not accept file path as a variable.
Could you please help me with that?
Best Regards,
Armen
    Hi Armen,
    I suggest you use a recent-ish version of IC617 (I think it was added during IC617) and use nport rather than n3port (you can specify three ports). Then there's a checkbox to allow you to specify it as a variable:
    This stops the component being netlisted with quotes around the file name, and allows you to parameterise it.
  • armenhr
    armenhr over 7 years ago in reply to Andrew Beckett
    Thank you very much, Andrew!!!
