  3. analogLib switch component not switching
  • Views 26145
MatthewLove
MatthewLove over 7 years ago
I'm trying to use the switch model in analogLib to emulate a PMOS for an ideal inverter stage.
When the switch is closed, the impedance is 1T Ohm and when it is open, it's 1m Ohm.
This works in isolation with the following circuit.
You can see in the ViVA plot that the impedance is 1T when the input voltage is 800 mV.
When this switch is included in the inverter circuit with another switch (that's meant to emulate an NMOS), the impedance of the PMOS is fixed to 1m Ohm whereas the "NMOS" is switching as expected.
Does anyone know why it ceases to work in this schematic?
    Andrew Beckett over 7 years ago in reply to MatthewLove +1
    Hi Matthew, I'm not entirely sure what you want here, but because the top switch (relay) has the inputs reversed, the voltage across the inputs is always negative (so that means you are sweeping it from…
  • MatthewLove
    While the images are extremely blurry, you can view them clearly by clicking on them.
    Can you please post the input.scs to avoid me having to guess the parameters you're using?
  • MatthewLove
    MatthewLove over 7 years ago in reply to Andrew Beckett
    Sorry about that.
    I've included the .scs files for both circuits.
    Matthew
    (I'll paste them here in case they haven't uploaded properly; I dragged them into the editor and they "uploaded" but nothing has appeared.)
    single_switch.scs
    // Generated for: spectre
    // Generated on: Oct 18 11:08:51 2018
    // Design library name: scratchpad
    // Design cell name: switch_test_mwe
    simulator lang=spectre
    global 0
    parameters Vin_DC=0
    include "$SPECTRE_MODEL_PATH/design_wrapper_rf.lib.scs" section=tt_pre
    include "$SPECTRE_MODEL_PATH/soa_rf.scs"
    // Library name: scratchpad
    // Cell name: switch_test_mwe
    // View name: schematic
    W1 (0 0 net1 0) relay vt1=100.0m vt2=700.0m ropen=1 rclosed=1T
    PORT0 (net1 0) port r=50 dc=Vin_DC type=sine edgetype=linear
    simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
        tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
        checklimitdest=psf
    dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
    dcOpInfo info what=oppoint where=rawfile
    dc dc hysteresis=yes param=Vin_DC start=0 stop=0.8 oppoint=rawfile \
    save W1:res
    Inverter.scs
    // Generated on: Oct 18 11:07:09 2018
    // Design library name: scratchpad_class_d_stacked
    // Design cell name: ideal_class_d_mwe
    global 0
    parameters Vin_DC=0
    // Library name: scratchpad_class_d_stacked
    // Cell name: ideal_class_d_mwe
    V0 (net05 0) vsource dc=2.4 type=dc
    W4 (M2_D net05 0 net02) relay vt1=100.0m vt2=700.0m ropen=1 rclosed=1T
    W1 (0 M2_D net02 0) relay vt1=100m vt2=700.0m ropen=1T rclosed=1
    PORT2 (net02 0) port r=50 dc=Vin_DC type=sine edgetype=linear
    PORT1 (M2_D 0) port r=50 type=sine
        checklimitdest=psf
    save W4:res W1:res
    Hi Matthew,
    I'm not entirely sure what you want here, but because the top switch (relay) has the inputs reversed, the voltage across the inputs is always negative (so that means you are sweeping it from 0 to -0.8V). If you swap the inputs to the top switch, then it does transition as you sweep Vin_DC from 0 0.8 (since you've switched the on and off resistances, I don't think you also want to invert the control voltage - if you do, you'll need to adjust the thresholds accordingly). This is what I get with W4 as:
    W4 (M2_D net05 net02 0) relay vt1=100.0m vt2=700.0m ropen=1 rclosed=1T
    By the way, I'm not sure why you are using two port components - it seems a bit bizarre having a port when you're driving a high impedance input... why not use a vsource for the Vin_DC input? After all, what is going to happen is that the voltage on the output of the port will be double what you have asked for, because you specify the voltage with the assumption that the load on the port is matched to the 50 ohm impedance, which it isn't here - the high impedance of the relay input means that you'll get double the voltage instead.
  • MatthewLove
    Thanks for the detailed reply.
    I wasn't aware that the switch polarity was a factor but your reply has cleared it up for me.
    You're right. I misinterpreted the documentation and should have just used a voltage source.
    Thanks for pointing that out.
    Matthew
