  3. Export Monte Carlo yield corner data in CSV
  • Views 16869
David Alldred
David Alldred over 7 years ago
I'm using ADE Assembler (ICADV12.3-64b.500.21) and ran Monte Carlo mismatch on 4 corners for a circuit.  The yield results display has the mean/min/max/std dev for each numerical result by corner (expands when I click the '+' beside a result), perfect.
We like to export results to CSV whenever possible so that they can be stored as text for future reference and generating reports.  When I export CSV of yield results though I only get the 1 row for each result, the corner data is not there.
Is there anyway to get it to expand all the corner results in the CSV output?  If not I guess I have to either 'export' the yield corner results by hand (ie. retype them), or export the whole data set and re-calculate the statistics for each corner/result.  Both seem pretty lame when the data I want is right there it just can't seem to find its way out...
Thanks.
  • Marc Heise
    Marc Heise over 7 years ago +1
    Hi David, in the yield output view, right click the test and select "expand" for this or all tests before the export. Did work for me. Kind regards, Marc
  • Marc Heise
    Hi David,
    Kind regards,
    Marc
  • David Alldred
    David Alldred over 7 years ago in reply to Marc Heise
    This worked.  It didn't do anything when I expanded only a few results before the export, but doing it this way for the entire test(s) works.  Thanks!
