  3. Loading bindkeys
  • Views 17593
Loading bindkeys
skillEater
skillEater over 7 years ago
I want to load my bindkeys automatically when ever I invoked icfb everytime.
I tried by copying in to my workspace. But its not working.It worked previously. But its not working now.
Please help me.
Ganesh Doddipatla
  • Marben
    Marben over 7 years ago
    Hi Ganesh,
    Try to put your bindkeys in your .cdsinit file.
    Hope it helps.
    Best regards,
    Marben
  • skillEater
    skillEater over 7 years ago in reply to Marben
    Hi Marben,
    I tried to open open .cdsinit but there is no .cdsinit file in my workspace.
    So I searched by using command cdswhich -all  .cdsinit . It said there is no such file.
    Then I created file .cdsinit I tried giving the whole commnad and next I tried giving only path. But its not working.
    Please could you help me by giving more details on this.
    Ganesh Doddiptatla
  • skillEater
    skillEater over 7 years ago in reply to skillEater
    Thanks Marben. It worked
    After that I read about .cdsinit some times . cdsinit can be .cdslocal so I searched .cdslocal it is there I changed it.
    Thanks once again
    Andrew Beckett over 7 years ago in reply to skillEater
    Note that a file called .cdslocal is purely something that is coded in a specific customer environment - there is nothing in the Virtuoso tools that looks for a file called .cdslocal. Customers have a variety of different names for such local customisation files, including .cdslocal, .cdsuser, and many others...
  • skillEater
    skillEater over 7 years ago in reply to Andrew Beckett
    Thanks Andrew for the explanation.
    But I have some questions and I wish you would help.
    As I said earlier in the chain I created a .cdsinit file and loaded loaded bindkeys.
    So then I loaded two bindkeys files(Which are in .cdsinit and .cdslocal).
    Which one it will give priority.
    And also I have multiple .cdsenv files for different technologies at different workspaces which  one will it take.
    could you explain more about this or direct me to a chain where it is explained more.
    It will help me a lot.
    Thanks again
    Ganesh Doddipatla.
