  3. Error "version `GLIBCXX_3.4.15' not found" when running...
  • Views 2107
Error "version `GLIBCXX_3.4.15' not found" when running PVS LVS in command line
Mamad
Mamad over 7 years ago
If I run PVS LVS from GUI, it is working without any problem. However, when I am trying to run it from command line with the following command I will get an error as shown later below.
/CMC/tools/cadence/PVS16.12.000_lnx86/tools.lnx86/pvs/bin/64bit/pvsvirt
-mode lvs
-global_log_file /home/mt2775_loc/tutorial_FinFET/PVSLVS/pvsuilvs.log
-control /home/mt2775_loc/tutorial_FinFET/PVSLVS/pvslvsctl
-df2_version ICADV12.3.0
-run_dir /home/mt2775_loc/tutorial_FinFET/PVSLVS
-no_rules_check
-qrc_data
-schLibName workspace_finfet
-schCellName interver
-schViewName schematic
-simViewList auCdl schematic
-simStopList auCdl
-displayPinInfo
-source_cdl /home/mt2775_loc/tutorial_FinFET/PVSLVS/interver.cdl
-spice /home/mt2775_loc/tutorial_FinFET/PVSLVS/interver.spi
-layLibName workspace_finfet
-layCellName interver
-layViewName layout
-igds /home/mt2775_loc/tutorial_FinFET/PVSLVS/interver.gds
-layScale 0.0005
-layTechLib cds_ff_mpt
-convertPin geometry
-replaceBusBitChar nil
-noConvertHalfWidthPath nil
-layHierDepth 32
-layMaxVertices 2048
-enableColoring yes
-rulesFile /home/mt2775_loc/finfet/pdk/cds_ff_mpt_v_0.4/pvs/pvlLVS.rul
Although I just copied the command from PVS LVS GUI, there would be an error as below.
/CMC/tools/cadence/PVS16.12.000_lnx86/tools.lnx86/pvs/bin/64bit/pvsvirt: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by /CMC/tools/cadence/PVS16.12.000_lnx86/tools.lnx86/pvs/bin/64bit/pvsvirt)
Would you please help me to resolve this error?
Thanks for your help
  • Saloni Chhabra
    Saloni Chhabra over 7 years ago
    Hi Mamad,
    I ran a quick test after replying to you and found that 'pvsvirt' is an executable you can launch standalone. So, ignore my last message.
    All you need to do is to replace '/CMC/tools/cadence/PVS16.12.000_lnx86/tools.lnx86/pvs/bin/64bit/pvsvirt' with 'pvsvirt' to run the command in batch-mode i.e. command should look like (note the continuation character at the end of every line) :
    pvsvirt \
    -mode lvs \
    Saloni
  • Mamad
    Mamad over 7 years ago in reply to Saloni Chhabra
    Hi Saloni,
    Thank you very much for your help. It works well based on your suggestion!
    Regards
    Mohammad
