  3. Bsource tutorial
  • Views 21962
Bsource tutorial
IcoNem
IcoNem over 7 years ago
Hi all,
I should try to use a bsource to model a VCVS with a given expression for the relation input-output. I should put in the expression the value of the voltage of a node of the net, how can I do this?
I have tried to put the name (Vtry) I gave to such node, but I get the following error:
Error found by spectre during hierarchy flattening.
ERROR (SFE-1997): "input.scs" 183: I46: parameter `bs_par_0': Cannot run the simulation because an unknown parameter `Vtry' has been specified in expression `Vtry'. Correct the expression and rerun the simulation.
Also I have not managed to find any tutorial for beginner about how to use bsource, if you know any would be helpful.
Thanks for your help
    First of all, could you not just use a vcvs? Or maybe the "pvcvs" or "pvcvsp" component from analogLib? You should only need to use bsource if you have a sufficiently complex expression rather than a straightforward polynomial expression of a set of input voltages.
    You can find out more about bsource by typing "spectre -h bsource" at the UNIX prompt.  You can also find out about vcvs using "spectre -h vcvs" and pvcvs/pcvcsp (the latter is just a special symbol with a variable number of control inputs - underneath it's just spectre's pvcvs though) using "spectre -h pvcvs".
    Andrew Beckett over 7 years ago in reply to Andrew Beckett
    Oh, and giving the actual expression you'd tried to use would be a good idea as then a more specific suggestion could have been made as to what the problem was.
