  3. how to rename all the cell in the standard cell library...
  • Views 18960
how to rename all the cell in the standard cell library by scripts?
enzhu
enzhu over 7 years ago
Hi All,
I am making the standard cells for analog team usage. We like to use different isolation rings. So we like to have a different cell name to identify them.
V5_AD2D1 --> V5_NBL30V_AD2D1
V5_MX2D1 --> V5_NBL30V_MX2DA
The new naming means that the cells are 5V with 30V NBL to sub breakdown volage.
The whole standard cell have a very consistent naming as: V5_{cell_name} and needs it to be V5_NBL30V_{cell_name}.
Can any one help to provide a simple script to run across the whole lib?
Thanks.
Enzhu
    Hi Enzhu,
    There are a number of articles on the support site which may help with this:
    • Using ccpCopy() to copy library, how to allow different prefix/suffix added to the copied cells based on original cell name being copied
    • Using SKILL, how can I copy my design into a new library and also add a prefix/suffix to copied cells.
    • SKILL function to rename some cells specified in a file, add prefix or suffix.
    • SKILL: How to rename all cells starting with a given prefix or ending with a given suffix and update references of all cellviews in a library.
    There are others too. I just searched for articles with the keywords "copy cell prefix". I didn't check the suitability of any of these articles, but hopefully one of them will do what you want!
