  3. SPECTRE SP analysis -- noise correlation matrix
  • Views 3180
Yevgeny
Yevgeny over 7 years ago
Good day.
I am running the following simple simulation (spectre 17.1.0):
rx (xx yy) resistor r=50
port11 (xx vssa) port r=50 isnoisy=no
port12 (yy vssa) port r=50 isnoisy=no
sp sp ports=[port11 port12] start=100M stop=1G dec=80 \
    donoise=yes file="res.s2p"  datafmt=spectre paramtype=s noisedata=cy annotate=status
This is a 50Ohm resistor, connected between two 50 Ohm noiseless ports. When I look at the resulting file "res.s2p" I see the S-parameter noise correlation matrix:
0.023      -0.023
-0.023      0.023
I would like very much to understand how this matrix defined in SPECTRE, since I fail to arrive at these numbers no matter how I try to define the matrix.
The S matrix itself is, by the way, perfectly sound:
1/3 2/3
2/3 1/3
I also tried to use "paramtype=y" (i.e. Y params instead of S params), the noise correlation matrix becomes:
0.02    -0.02
-0.02   0.02
which makes perfect sense (Y-param noise correlation, i.e. 1/R, if I divide by 4kT df).
I apologize ahead if this is some stupid numerical error on my behalf; have spent quite some time on this, and could find nothing in docs. I filed cadence support request, but perhaps knowledgeable folk will answer faster Slight smile
Help is much needed.
Thanks!
  • Yevgeny
    UPD: I continue working on this. I run SP analysis on a real circuit (quite complex, transistors, inductors, using Intel proprietary modes through CMI, and such).
    I run it once with "paramtype=y noisedata=cy" and the second time with "paramtype=s noisedata=cy". I look at noise correlation matrix (CY) and discover something disturbing:
    with "paramtype=s" I get non-negative eigenvalues, but with "paramtype=y" I get both positive and negative eigenvalues. The negative ones are large; can not be attributed to floating-point arithmetic errors.
    To make my point clear: Correlation matrix is supposed to be positive semidefinite, and since it is Hermitian by construction, it should have had only non-negative eigenvalues. I have to conclude that the matrix provided by "paramtype=y" is broken!
    So far, one good thing has come out of it: I have refreshed some undergrad algebra.
    Andrew Beckett over 7 years ago in reply to Yevgeny
    I would suggest you provide this info to the AE dealing with your case rather than posting it here. I'm not going to duplicate work done by a colleague (I don't have the time, for a start), so I suggest you follow up via the official channel.
