  3. transient simulation result not available by RMB->Plot,...
  • Views 1366
transient simulation result not available by RMB->Plot, but available in result browser
sjwprc
sjwprc over 7 years ago
Hi, I face a problem that I sweep more than 1K corners transient simulations. When it finish without any error, I can't use RMB-plot to show the curve, e.g., "plot across corners". It gives the warning in CIW as transient sim result not available. But when I open result browser, I could display the transient curve there.
Is there any solution for this, I don't want to re-sim so huge test bench again.
BR
    Unfortunately there's not really much info to go on here (you didn't even mention which version of the tools you're using). I suggest  you contact customer support (although I'd try in the latest tool subversion first if you're not using that).
