  3. Re-characterizing a tap-less cell library (Cadence Liberate...
  • Views 17755
Re-characterizing a tap-less cell library (Cadence Liberate)
anurans
anurans over 7 years ago
Hi All,
I want to re-characterize the existing library to a lower supply voltage. I have been provided the extracted (with parasitics) netlist (.cir) of this tap-less cell library by the vendor.
> I generated the cell template file from existing .lib in .tcl format which contains cell definitions, delay/power templates with slew/load indices.
> The provided netlist however contains the VBN/VBP contact ports (along with its parasitics) which are not available in generated template (I assume the earlier characterization was done by connecting well contacts to the supply rails accordingly / or atleast that's what I'd do if I create a lib for my custom made cells).
> In this condition, re-characterization is not possible as Liberate does not see VBN/VBP in cell definitions of the template. Is it possible to indicate "Liberate" that those well contacts should be connected globally to respective supply rails during the characterization ?
> When doing the characterization, are those slew values for the given loads automatically re-calculated for the new supply voltage ?
Anuradha
    Andrew Beckett over 7 years ago in reply to anurans +1
    This is the wrong forum. It should be in the Custom IC Design forum (perhaps not obvious, but that's where Liberate questions are practically answered). Unfortunately whilst I'm a moderate, I don't have…
  • Guangjun Cao
    Guangjun Cao over 7 years ago +1
    1. if you want the new library to have exact the same arcs, use -verbose in the write_template command, and -user_arcs_only in char_library command; 2. PG pins are not written out during write_template…
  • anurans
    Can anybody shed some light please ? Am I in the right forum ?
    Anuradha
    This is the wrong forum. It should be in the Custom IC Design forum (perhaps not obvious, but that's where Liberate questions are practically answered). Unfortunately whilst I'm a moderate, I don't have the ability to moderate in this forum for some reason so I can't move your post.
  • anurans
    anurans over 7 years ago in reply to Andrew Beckett
    Hi, I originally made the post in digital design, somehow it was moved to this forum (by a moderator?). Will make a new post in Custom IC Design.......
    Anuradha
    Now it's in the Custom IC Design forum. I guess somebody moved it!
  • Guangjun Cao
    2. PG pins are not written out during write_template. users have to use set_vdd/gnd or set_pin_vdd/gnd to declare/define the PG pins and association of pin/PG-pins;
    3. if your reference library has normalized waveform, you can write out this and re-use it for re-characterisation. slew/load index tables are not necessarily related to supply for a give corner. If you want the tool to auto-calculate the index table, you need to specify the min/max_transition of your design and minimum input capacitance, which can all be corner dependent as your cells' behavior. -auto_index is also needed. you can also use -driver_waveform to include the normallized waveform in the generated library. Some STA tools use this information, which can improve the correlation between Spice simulation and STA analysis results.
