  3. Simulating kT/C noise in discrete-time delta-sigma
  • Views 4109
Nicolas Callens
Nicolas Callens over 7 years ago
I am trying to get the transient noise of my switched-capacitor delta-sigma in VerilogAMS. The building blocks are all ideal except the switches, which are modelled as follows:
`timescale 1ns / 1ps
`include "disciplines.vams"
`include "constants.vams"
module noisySwitch(in, n, s);
    parameter real ron = 10.0 from (0:inf);    // on resistance (ohms)
    parameter real roff = 100.0M from (ron:inf);// off resistance (ohms)
    parameter real td = 0.0;            // delay time (s)
    parameter real tr = 20n;            // rise time (on -> off) (s)
    parameter real tf = 20n;            // fall time (off -> on) (s)
    input s;
    logic s;
    electrical in, p, n;
    real reff;
    analog begin
    @(posedge s) reff = ron;
    @(negedge s) reff = roff;
    @(initial_step) reff = (s ? ron : roff);
    V(in,p) <+ white_noise(4*`P_K*$temperature*reff,"thermal");
    I(p, n) <+ V(p, n) / transition(reff, td, tr, tf);
    end
endmodule
However, I am getting zero transient noise while simulating in transient mode. I have the feeling that the white_noise can only be seen in small-signal analysis and not in transient simulations? If so, how can I get the transient noise from these switches?
Kind regards,
Nicolas
PS: I actually need transient noise for my own purposes and not pnoise results...
    Andrew Beckett over 7 years ago in reply to Nicolas Callens +1
    You don't need to explicitly tell it to turn on noise contributions - in fact that wouldn't have made any difference unless your model had a special parameter isnoisy which allowed the noise to be turned…
    Nicolas,
    A few things:
    1. This appears to be an incomplete VerilogAMS model (not VerilogA). It doesn't define p, for example. Was also missing the include of constants.vams too.
    2. I'm assuming you're therefore running AMS Designer
    3. Did you specify noise fmax on the transient noise section of the transient form with AMS as the simulator? Without this, no noise will be produced
    I'm not entirely certain your model makes sense, but that's just because I don't know precisely what it's attempting to model, and it's incomplete. However, simply declaring p as electrical and then simulating in AMS Designer and setting the noise fmax and looking at the voltage on both in and n pins of the sw component shows noise.
  • Nicolas Callens
    Nicolas Callens over 7 years ago in reply to Andrew Beckett
    My apologies, I have shown you the wrong VerilogAMS code. I have edited my code (see above). In the meantime, I have tried it with a network which consists of a switch (VerilogAMS model) and a capacitor in series (see attachment), but still it does not work.
    To answer your remaining questions:
    2. Yes, I am using AMS Designer.
    3. Yes, I have given in an fmax; actually I have tried with several fmax (e.g. 1G and 100G) just to test if I am getting transient noise in the simulation. I have also turned on the noise contribution and selected instance noisy-switch.
    Kind regards,
    Nicolas
    You don't need to explicitly tell it to turn on noise contributions - in fact that wouldn't have made any difference unless your model had a special parameter isnoisy which allowed the noise to be turned on or off.
    I used your model (renamed to "sw") and in my simple testbench:
    Which corresponds to this netlist:
    sw I0 (.in( o1 ), .n( o2 ), .s( net2 ));
    resistor #(.r(1000), .isnoisy("no")) R1 (o2, cds_globals.\gnd! );
    resistor #(.r(1000), .isnoisy("no")) R0 (o1, cds_globals.\gnd! );
    vsource #(.type("pulse"), .val0(0), .val1(1.8), .period(2e-07), .rise(2e-08), .fall(2e-08), .width(1e-07)) V0 (net2, cds_globals.\gnd! );
    (so you can see all the parameters), I get:
    So clearly I'm getting noise.
    I didn't try to check with the same testbench as you as I don't know the parameters - but clearly noise is being produced.
    So it either means your circuit is such that the noise is insignificant, or that you're using a version of AMS Designer where this wasn't supported, maybe. What INCISIVE or XCELIUM version are you using? (The AMS simulation log - probably irun.log or xrun.log - will tell you this).
  • Nicolas Callens
    Thanks for trying. The version of INCISIVE that I am using now is 15.20.
    I have tried with your circuit and I am getting the noise in the transient simulation. Step-by-step I have replaced the instances towards the circuit I have. Though, after adding the capacitor it did not work out. Then I realised that 1pF for the C would be to large to see the noise... Indeed,  I changed the value to 1fF and I get a huge amount of noise like It should be.
    Kind regards,
    Nicolas
