  3. Using Simulation Variables and Outputs in MDL File
  • Views 15393
baltacican87
baltacican87 over 7 years ago
I am using Virtuoso version IC6.1.7.
I would like to stop the transient simulation that I perrform in ADE L by using autostop option. For that, I use an MDL file, where I define an event driven expression that would stop the transient simulation immediately after its calculation. Everything works fine normally, but I cannot use any simulation variables or outputs in MDL file. I have two questions regarding this
1) How can I use the variable that I define in ADE L window in MDL file in different expressions?
2) How can I use the output that I define in ADE L window in MDL file in different expressions?
Many thanks in advance.
Best regards,
Can
