  3. Schematic Editor Create Instance Form - Auto-completion
  • Views 1240
pnarayan
pnarayan over 7 years ago
Hello, In the schematic editor, how does one enable the the auto-completion feature for the 'Library', 'Cell' and 'View' fields? Furthermore, I would like the 'View' field to default to 'symbol'. Is this possible?
Cadence Help document says "The Library, Cell, and View text fields, which can be auto-completed", but no indication of how this is actually done. My Virtuoso version: ICADV12.1-64b.500.15.2. \
Pritish
    You're using too old a version - I suspect you must be looking at the help for a newer version. You should use ICADV12.3.
  • pnarayan
    pnarayan over 7 years ago in reply to Andrew Beckett
    Hi Andrew, thank you. I was able to get this to work on 12.3-64b.500.19.
