  3. Filtering data to plot for nested sweeps
  • Subscribers 129
  • Views 15714
ZoltanT
ZoltanT over 7 years ago
Hi Everyone,
I've run nested sweeps in spectre and I would like to filter the data, what I postprocess and plot with OCEAN. Let's say I want to plot the results with a fixed value of the second sweep, or for a range of another sweep, or some combinations of them. I have not found any ready to use solution for that in OCEAN. I am aware of the value and famValue functions, but one can only select one value from the outer sweep.
Ideally I am looking for a function like "my_value(o_waveform "sweep_name" list(sweep_value_of_interest))" . I guess with the fam* functions one can create a multidimensional list of sweep names and values and filter that and get back the results point by point, which can be gathered into a waveform, but I feel it cumbersome (for me at least) and slow. I do not think this is the right way in OCEAN, but I do not know a better one.
Of course there is always the option to export all the data, and read it in with another program (python, matlab, etc) and do the filtering there, but there must have been an easy way to that in OCEAN.
To give a real life example why I would like to do that: I've just run some transistor characterisation simulation where I swept the gate, drain and bulk voltage relative to the source:
sw_b sweep param=VB values=[0 1 2] annotate=sweep {
sw_d sweep param=VDS start=0 stop=0.9 step=0.1 {
sw_g sweep param=VGS start=0 stop=0.9 step=0.1 {
  • ZoltanT
    Update: I can add value() the argument of the sweep parameter. I missed it, because I assumed that I have to state the sweep analysis name. User error. I am one step closer, though I do not know yet, how can I filter the parameter values. If I could have a list of all values for a given sweep parameter as a list, I can use some mapping and plot everything one-by-one.
    Andrew Beckett over 7 years ago in reply to ZoltanT
    The value function (there's also the leafValue function if you want to conveniently give more than one sweep variable rather than having to nest multiple value() calls) doesn't accept a list of values.
    However, you can find out the swept values with sweepValues() - gives the outermost sweep values, sweepNames() - tells you the names of the swept parameters, and sweepVarValues() which allows you to find the values for a particular sweep name. So then you could do the loop you want, I think?
  • ZoltanT
    ZoltanT over 7 years ago in reply to Andrew Beckett
    Thanks for tips! They helped a lot.  I was able to create it.
