  3. Using system gcc instead the MMSIM one during ahdlcmi c...
  • Subscribers 133
  • Views 17291
Using system gcc instead the MMSIM one during ahdlcmi compilation
Johanny Saenz
Johanny Saenz over 7 years ago
Hi all!
I'm having problems during VerilogA compilation and the spectre.out show me the following error in MMSIM 15.1.0.257
ERROR (VACOMP-1008): Cannot compile ahdlcmi module library.
Checking in the ahdlcmi.out file, I get the following problematic line:
ld: cannot find -lc
collect2: error: ld returned 1 exit status
Executing the same command that is contained in the ahdlcmi.out file but replacing the gcc version contained on MMSIM folder ($MMSIMHOME/tools.lnx86/cdsgcc/gcc/4.8/bin/gcc) by the gcc command available on the system, there is no longer error.
I want to know how I can redirect the gcc to be the same of the machine and not the used by Cadence
gcc version 4.8.3 (Cadence)
gcc version 4.9.2 (Linux)
Thanks!
    I don't think this is due to the gcc version being used, but probably that you are running spectre in 32-bit mode and you don't have the 32-bit libc installed on your machine (normally in /usr/lib/libc.so). Can you try running spectre in 64-bit and see if that fixes it?
    You can do this in ADE by turning on 64 bit mode on Setup->Environment or you can set this before starting virtuoso:
    setenv CDS_AUTO_64BIT ALL
    if using csh, or:
    export CDS_AUTO_64BIT=ALL
    if using bash/ksh. Note you could just set the env var to spectre rather than ALL if you only want to enable spectre in 64 bit mode, but probably simplest just to enable everything. Virtuoso is always 64-bit in IC617 onwards anyway.
  • Johanny Saenz
    Johanny Saenz over 6 years ago in reply to Andrew Beckett
    Hi Andrew!
    I have solved this issue creating a symbolic link named {$CDS_DIR}/MMSIM15.10.257/tools.lnx86/cdsgcc/gcc/4.8/bin/gcc to the gcc system (/usr/bin/gcc).
    I thought that MMSIM15 automatically would use the gcc version from the system. How can I configure it?
    Thanks!
    Andrew Beckett over 6 years ago in reply to Johanny Saenz
    That absolutely should not be required (and is not recommended). We intentionally use the gcc we ship as that is both tested, and also will then produce a shared library that is compatible with the compilers used to build spectre. I suspect you've just worked around the real issue (I'm not sure why your change fixes it). Please contact customer support so that we can investigate what is really wrong with the setup of your machine that causes this to fail.
