  3. CDF for NOT GATE
  • Subscribers 133
  • Views 16250
CDF for NOT GATE
tiennv
tiennv over 7 years ago
Hi everyone,
i have a problem when i create CDF parameter for not gate.
this is error "ERROR (SFE-1997): "input.scs" 16: ND0.M2: parameter `w': Unknown parameter name `WP' found in expression"
i change paramter of pmos: width: [@WP:%:2u],length: [@LP:%:0.35u], same for nmos
and then i go to Tool/CDF/edit--> add CDF parameter
but when i finish, it show a warning like this:
"Warning: Warning: ams.env
Fatal: Error loading environment variables from environment file.
Terminating execution."
can you help me how to fix it? did i do wrong step to make CDF parameter?
Thank you so much.
    I doubt the fatal error is anything to do with the CDF change you've made. It also seems a bit odd that you're using NLP expressions for parameter passing - that's not usual for most ADE users (NLP expressions are the old-school "digital" flow and use this [@WP:%:2u] type syntax - usual ADE flow would be to do pPar("WP") instead).
    Perhaps you should contact customer support so that we can take a closer look at what you're doing and attempting to do? Otherwise there will need to be a lot of guesswork as how things are set up.
  • tiennv
    tiennv over 7 years ago in reply to Andrew Beckett
    Thank you.
    So you mean I need to check all CDF I have changed. This is first time I doing on CDF. based on old symbol, I try to make new one. but, I did something wrong, so old symbol doesnot work.
    Andrew Beckett over 7 years ago in reply to tiennv
    I've no idea. I don't have enough visibility as to what you have done, I'm afraid.
  • tiennv
    I see. Thank you.
