  3. How to export schematic images for all the cellviews in...
  • Views 17287
How to export schematic images for all the cellviews in a config at once
Emiel
Emiel over 7 years ago
I have a project with a lot of different (nested) cell views.
I would like to print out images of all the used cell views (in the config file).
I've found some settings for 'Export Image...' that works great, but only for one sheet at a time. To print them out one by one manually is quite cumbersome.
Is there a way to automatically export all the cell view images within a config file with certain export image settings?
    You could use the Export HTML functionality in Virtuoso Schematic Editor XL which will export an XML description of the hierarchy and images of each schematic and an XSLT style sheet to transform it to HTML.
    Or you could write some SKILL code to traverse the hierarchy (probably starting from the hdbTraverse.il example in the IC installation hierarchy) and call hiExportImage for each schematic found.
