  3. facing problem with plotting waveforms
  • Views 14611
akkumar4444
akkumar4444 over 7 years ago
 Even after completion of simulation(in output log showing successfully completed), in adexl state its still showing running state. But when i tried to plot those running state plots, im able to plot few signal but not all.
Ashok
    Ashok,
    First of all, it's a good idea to post this in the right forum. You posted it in the general feedback and suggestions forum, which is for questions about the forum itself rather than technical questions - luckily I noticed it and moved it into a more appropriate forum. Then it's worth checking the Forum Guidelines for each forum (if they have them) - you'd have seen that providing as much information about your issue as possible (including the version used) makes sense.
    In this specific case I'd suggest first moving to the latest hot fix of IC617 (say) and if it still is a problem, then contact customer support. Almost certainly this will be something data or environment specific which will be pretty hard to debug through the forums.
