  3. Change the tooltip text color in Cadence VirtuosoICADV12...
  • Subscribers 128
  • Views 13561
Change the tooltip text color in Cadence VirtuosoICADV12.3
bitan9891
bitan9891 over 6 years ago
How can I change the tooltip text color from white to black?!
Currently it is white text with background red, hence visually it is not clear.
I want to change the tooltip text color to black with background red/white. Kindly let me know the procedure.
Thanks and Regards,
Bitan
    Hi Bitan,
    This probably depends on which window manager you're using. I've come across this in newer KDE versions - and this article describes how to fix it. This is an issue with the Plasma desktop. The suggestion is:
    In KDE Control Center, under Appearances and Themes -- Color settings: There are a couple of resources called:
    Tooltip Text - This is set to white by default
    Tooltip Background - This is set to black by default
    Change the text color to black and the background to white. The background is still the pinky-red sort of color, but the text changes. I've not confirmed this as my primary machine is not running a new enough KDE desktop (I'd have to reboot to a different OS version to check).
    Of course, if you're not using KDE, the solution may be different...
