  3. Cadence Liberate Characterization of Complex Logic Cell...
  • Replies 28
  • Views 32972
Cadence Liberate Characterization of Complex Logic Cells
anurans
anurans over 7 years ago
I am trying to characterize a combinatorial circuit which has 5 (A, B, ...., E) inputs and 3 outputs (X, Y, Z). As per the cell behavior, output Z does not depend on input E. When I perform the characterization without user defined "define_arc" s, the process fails trowing following error :
ERROR (LIB-54): Some output transitions did not cross both 'measure_slew_*' thresholds for arc of cell:'UTCOMX', r_pin:'E', r_pin dir:'r', pin:'Z', pin dir:'r', type:'combinational rise_transition' when: (!D * A * B * !C). To debug, review the saved simulation results for deck: delay_21. Possible solutions include setting 'extsim_exclusive' to 1 and 'sim_estimate_duration' to 0 with increased 'sim_duration' as needed, and rerun.
My questions are :
1. Can we use define_arc in following format to include only valid logical states [ in this case removing E (-related pin) to pin Z (- pin)] for the given cell ?
//Assume that pin_list order is A B C D E X Y Z
//define_arcs for A -> Z transitions
define_arc \
- vector {RXXXXXXR} \
- related_pin A \
- pin Z \
UTCOMX
define_arc \
- vector {RXXXXXXF} \
- related_pin A \
- pin Z \
UTCOMX
//Same routine goes for B -> Z, C -> Z .... and other combinatorial states except E -> Z !
2. In 1.) case, let's say we do not specify "- type" (i.e. hidden, power or delay) inside define_arc ! Does Liberate still calculate hidden, switching power and delay values for each define_arc state automatically ?
3. Is there an easy way to exclude E -> Z monitoring without specifying the define_arcs manually for all other states ?
Thanks in advance
Ranaya
  • Guangjun Cao
    Guangjun Cao over 7 years ago +2
    1. if you want to make sure all possible arcs to be characterized, you can start with char_library -trial to generate a dummy .lib file, Then, use read_library-->write_template -verbose to dump all the…
  • Guangjun Cao
    Guangjun Cao over 6 years ago in reply to BarPouy +1
    the message is very clear. have you tried anything following the message? as a quick test, you may remove -auto_index and define your own load index, save the deck. if the error happens again, check…
  • Guangjun Cao
    Guangjun Cao over 6 years ago in reply to anurans +1
    I do not believe this issue is worth further discussion, until one define_cell for each cell is used. There is no point to look into all the scripts. The approach, clearly as it has been, has caused more…
  • Guangjun Cao
    as a quick test, you may remove -auto_index and define your own load index, save the deck. if the error happens again, check the decks. run spectre on the decks and check if the waveform show expected transitions at all ports.
    Guangjun
  • anurans
    anurans over 6 years ago in reply to BarPouy
    BarPouy said:
    the maximum load for AN2d1:Z is smaller than the specified min_output_cap (2.8181e-16F <= 1.07555e-15F)
    Mmm.... how did you specify the min_out_cap ? When liberate fails to find appropriate max_cap means, your max_transition is not suitable for the auto_indexing calculation. The max_cap is always measured with respect to the max_trans defined in the template. You need to adjust it properly....
    Anuradha
  • BarPouy
    BarPouy over 6 years ago in reply to Guangjun Cao
    Thanks a lot!
    I've not used -auto_index. I put manially all arcs for one cell in the template and run again. I get the same WARNING / ERROR.
    I used
    set_var max_transition 5e-08
    This should be enough for an AN2d1, even in subthreshold regime.
    Regards
    BarPouy
  • BarPouy
    BarPouy over 6 years ago in reply to anurans
    Thank you anurans!
    I increased the max_transition to 50 ns (set_var max_transition 5e-08) only to see what happen, actually it's too high even in subthreshold regime. As I designed and I did postlayout simulation (with Monte Carlo), the transition was much much lower.
    Regards
    BarPouy
  • anurans
    As Guangjun advised then re-run the failed decks. Locate the failed sim.sp file in the deck folder. Remove save=nooutput from .sp file and :
    spectre sim.sp
    then use viva to check the waveforms. You should see the failure of the cell given bisection search value.
    Anuradha
  • BarPouy
    I try to understand what you wrote. Aussuming the cell_nam is AN2d1. Do you mean I should generate AN2d1.sp in AN2d1 folder? Then 'remove save=nooutput from AN2d1.sp'. After that run spectre An2d1.sp. Finally check waveforms.
    I've not viva license, it should be also possible with ADE_L /XL?
    I will do that.
    Thank you!
    Regards
    BarPouy
  • anurans
    No, during the characterization you can save your simulation decks for debugging :
    set_var extsim_deck_dir /home/work_dir/decks_DDC_smth
    set_var extsim_save_passed deck
    (before char_library) !
    This deck folder should report simulation data for each cell in separate folders which could be PASS or FAIL. Locate the failed folder of your failed cell. It should have the sim.sp file.
    ADX should be possible. Viva is their visualization tool....
    Anuradha
  • Guangjun Cao
    1.Check the manual for correct sytanx and use these commands,
    set_var extsim_deck_dir full-path-here
    set_var extsim_save_failed deck
    set_var exism_save_passed none
    2. If your run has failed characterization at simulation stage, go to the deck dir. You will see saved deck dir or a tarball. Inside each sub dir, you will see a map.list. open this file you will see where the failure is. Find the deck (sim.sp)for the failed char, remove save=nooutput, then run spectra on it.
    3. Start viva with ade license. Open the simulation results and check the waveform.
    4. Review the settings and variables in the deck-- are they the same as your own test bench? If not, either your test bench or the characterization settings need to be corrected.
    Tip. select_index 2x2 may use min/max indecis, which makes the debug easier.
    Guangjun
  • BarPouy
    Hi Guangjun, Hi anurans,
    Thank you for your tips. I'm following it.
    Kind regards
    BarPouy
  • BarPouy
    Hello Guangjun
    Automatically generation of the template (with defined cells) for the cells having the same inputs /outputs, e.g. AN2d1 /OR2d1 (inputs: A1 A2) can be doen. However, If I mix such cells with the cells having more inputs /outpus or other inputs /outputs, e.g. AOI21.d1 (inputs: A1 A2 A3) or DFd1 (inputs: D, clock: CP, output: Q), then the template will not be generated and gives ERROR (see please below). It's clear, if I write for each class of cells, having the same inputs / outputs, a separate define_cell,  then this issue does not occur. There is an example of generating automatically template in the page 48 to 50 of 'Virtuoso Liberate Reference Maual', Version 18.1, section 'TCL Command File'. It shows that it might be possible to generate template of different class of cells like {NAND2X4 NOR2X2 DFFX1} just with one general define_cell.
    What is my mistake?
    Thanks!
    Kind regards
    BarPouy
    ERROR (LIB-520): (char_library): The pin 'D' is not defined for cell 'AN2d1'. This cell will be ignored. Check the netlist and make sure it is consistent with 'define_cell' command.
    ERROR (LIB-203): (char_library): Cell 'AN2d1' is scheduled for characterization but has no netlist, has an empty subckt or has no port on the subckt. This cell will be skipped. Check the netlist and rerun.
    ERROR (LIB-520): (char_library): The pin 'CP' is not defined for cell 'DFd1'. This cell will be ignored. Check the netlist and make sure it is consistent with 'define_cell' command.
    ERROR (LIB-203): (char_library): Cell 'DFd1' is scheduled for characterization but has no netlist, has an empty subckt or has no port on the subckt. This cell will be skipped. Check the netlist and rerun.
    ERROR (LIB-520): (char_library): The pin 'D' is not defined for cell 'OR2d1'. This cell will be ignored. Check the netlist and make sure it is consistent with 'define_cell' command.
    ERROR (LIB-203): (char_library): Cell 'OR2d1' is scheduled for characterization but has no netlist, has an empty subckt or has no port on the subckt. This cell will be skipped. Check the netlist and rerun.
    WARNING (LIB-961): (char_library): Leakage deck initialization was requested using '.ic', but the 'leakage_sim_duration' was set to '0'. This may lead to unexpected leakage characterization results. Change 'leakage_sim_duration' to a positive non-zero value in seconds or change the setting of 'set_sim_init_condition' and rerun.
    Building library database
    Processing cell: AN2d1
    Processing cell: DFd1
    Processing cell: OR2d1
