  3. COmmand to find Process Name
  • Views 17001
Nirmal Kumar
Nirmal Kumar over 7 years ago
Is there any command in cadence skill to find the process name Like if it is tsmcn28rf or other proces nodes
Please let me know
Nirmal.
    Hi Nirmal,
    There is no standard way of doing this because the process name isn't a requirement as part of any setup. Some might use an environment variable, some might not specify it at all.
    One thing you can do is get the name of the technology library to which your library or cellView is attached:
    cvId=geGetEditCellView()
    techGetTechFile(cvId
    )~>libName
    or for a design library name:
    techGetTechFile(ddGetObj("myLibName"))~>libName
    Maybe that's what you want?
  • Nirmal Kumar
    Nirmal Kumar over 7 years ago in reply to Andrew Beckett
    Thank you for your reply. In virtuoso in top left corner it displays process name as tsmcn28rf. as shown in the below screenshot.If we use other technology then it will display that technology.
    I want to get the Process name. Is there any way to get this name using skill command?
    nirmal
    Andrew Beckett over 7 years ago in reply to Nirmal Kumar
    Hi Nirmal,
    That is not standard Virtuoso behaviour - it's some customisation in your environment. Normally the window banner just says "Virtuoso® 6.1.7-64b - Log: /export/home/andrewb/CDS.log" Presumably somebody in your organisation knows the convention for how this window name is constructed and set?
    Otherwise you could potentially (in your environment) use:
    windowName=hiGetWindowName(hiGetCIWindow())
    extractPat=pcreCompile("^Process:(\\S+) ")
    process=when(pcreExecute(extractPat windowName)
      pcreSubstitute(extractPat "\\1")
  • Nirmal Kumar
    I found the command.
    getShellEnvVar("PROCESS")
    The code you told also works. Thank you
    Nirmal
