  3. vsource parameters cleared when changing source type
  • Views 15221
PhilMN
PhilMN over 7 years ago
I am experiencing an issue with the vsource from analogLib.  If I change the source type then then all the previously entered parameters in the form are cleared. I am remembering from past experience that the form should remember prior parameters so that you can switch back and forth between source types without having to re-enter them all.
It might have something to do with our site setup.  Any thoughts on where I could look?
Cheers,
Phil
    Hi Phil,
    This is a bug that was introduced in (I think) IC617 ISR10. I have a CCR (with a couple of duplicates) - CCR 1816593. Unfortunately the fix keeps being postponed - it's now not proposed until IC618 ISR5 (probably about June timeframe) and even then it's not committed.
    Reporting this via customer support and asking for a duplicate CCR to be created may help to bring this forward.
  • PhilMN
    PhilMN over 7 years ago in reply to Andrew Beckett
    Thanks very much Andrew, appreciate the response. Will do.
