  3. schematic search/replace criteria combination
  • Views 3075
sjwprc
sjwprc over 7 years ago
Hi guys,
     I am trying to do such replacement in schematic hierarchy: change all libName_A/cellName_A to libName_B/cellName_A, which means I need to combine libName and cellName together when I do search and/or replace. Anyone know such feature ?
BR
    Yes, on the Find/Replace form, use "master" as the Search For/Replace criteria, and then you specify the lib cell view in each field:
    (note, you should be careful doing this with PDK components as the CDF callbacks won't be called - I just arbitrarily filled in a lib/cell/view before taking a screenshot)
  • sjwprc
    sjwprc over 7 years ago in reply to Andrew Beckett
    clear, thanks for your help Andrew !
