  3. OCEAN: How to Check if a Corner is Enabled/Disabled?
  • Views 1868
khstangh
khstangh over 7 years ago
It is well described on the manual how to enable/disable corners. However I could not find a way to check when a corners is indeed enabled or disabled - since all corners are returned from ocnxlGetCorners() function.
Thanks for the support.
    I think you'll need to use some axl functions:
    sdb=axlGetMainSetupDB(ocnxlGetSession())
    enabledCorners=setof(corn ocnxlGetCorners() axlGetEnabled(axlGetCorner(sdb corn)))
  • khstangh
    khstangh over 7 years ago in reply to Andrew Beckett
    Thanks a lot for the fast response Andrew, that for sure solves it!
    I wonder if I missed some manual, or are those private functions?
    If they are listed somewhere, could you give me directions?
    Andrew Beckett over 7 years ago in reply to khstangh
    They're private - they're in the Virtuoso Analog Design Environment XL SKILL Reference. Or (in IC617 and later) you can use cdsFinder, search for the function, and then use the More Info button to take you to the documentation.
  • khstangh
    Perfect! Got it.
    Thanks again.
