  3. include file in subckt in ADE .
  • Views 15381
chqian
chqian over 7 years ago
My end goal is to get a netlist I don't need to touch. Is it possible to create an schematic_RCX view for a cell (regular schematic view) and add a component to that schematic which specifies a file to include in the netlist for that cell?
For example, when the netlist for the cell is created, the file will look like :
subckt block_name ....
// normal component lines
include "/path/to/user/specified/file"
ends block_name
// other component lines
Since there are components like PWL waveforms that can read files, this is of course feasible, but is it already available/easy is what I'm really after...
Thanks!!
I can not find the solution file ,pls give me the links
  • chqian
    Andrew Beckett ,would you pls help? thanks
  • Marc Heise
    Marc Heise over 7 years ago in reply to chqian
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nV4jEAE
