  3. Search single vias and replace with multi vias for selected...
  • Views 17289
Search single vias and replace with multi vias for selected nets
FrankVater
FrankVater over 7 years ago
 I am looking for a way to optimize existing layouts. Many layouts have too less vias on nets with a higher current (e.g. power nets). Maybe there is an easy built-in function in Cadence Virtuoso Layout Suite to do the following:
  • Select the net (e.g. using "Connectivity => Mark Net")
  • Specify the stop layer (eg. Metal1)
  • The tool looks for every single via of the marked net (or using PVS with via coverage)
  • For every single via the via  will be extend by a double cut via (or more), in case that there is enough space
Clearly the last point is very tricky because tool has to evalute the layout in every direction whether it is possible to extend the metals without creating DRC errors or shorts.
Does somebody knows a way?
Frank
  • Quek
    Quek over 7 years ago
    Hi Frank
    I think there is no built-in SKILL function to do via optimization directly by net but we can do it easily using the following SKILL procedure:
    procedure( CCSoptimizeVias(netName)
       let( (cv tf net cstGroup viaOpts win viaList viaPt)
          cv=geGetWindowCellView()
          tf=techGetTechFile(cv)
          net=dbFindNetByName(cv netName)
          cstGroup=cstFindConstraintGroupIn(tf "virtuosoDefaultSetup")
          viaOpts=viaGetViaOptions(cstGroup)
          win=hiGetCurrentWindow()
          unless( net error("Net %s cannot be found\n" netName))
          viaList=setof(x net~>figs x~>objType=="stdVia" && x~>cutRows==1 && x~>cutColumns==1)
          printf("Found %d single vias on net %s\n" length(viaList) netName)
          foreach( via viaList
             viaPt=via~>origin
             dbDeleteObject(via)
             viaGenerateViasAtPoint(win viaPt viaOpts)
          ) ;foreach
          printf("Job done\n")
       ) ;let
    ) ;procedure
    Best regards
    Quek
  • FrankVater
    FrankVater over 7 years ago in reply to Quek
    Hello Quek,
    I reviewed and I used the skill code and it works as I expected. It looks for single vias on the given net. In case that the overlap in the metal allows more than a single via this via will be replaced by an array. For me a function would be useful, which extents the metal and generates a via array afterwards. I think this skill code is a quite good starting point and I will investigate more time to extend the skill code!
    Thank you very much.
    Frank
  • Quek
    Quek over 7 years ago in reply to FrankVater
    Hi Frank
    Thanks for the update. : )
    Best regards
    Quek
  • FrankVater
    the viaGenerateViasAtPoint is one possibility. I found that viaRecomputeViasAtPoint  is also an option! Slight smile
    Frank
