  3. Generating spectre netlist using si gives unexpected bus...
  • Subscribers 133
  • Views 17016
Generating spectre netlist using si gives unexpected bus syntax
Lindi
Lindi over 7 years ago
I'm trying to make a netlist with si. I've created my si.env
simLibName = "myLib"
simCellName = "mySch"
simViewName = "config"
simSimulator = "spectre"
simNotIncremental = 't
simReNetlistAll = nil
simViewList = '("veriloga" "ahdl" "spectre" "schematic" "netlist")
simStopList = '("veriloga" "ahdl" "spectre")
simNetlistHier = 't
nlFormatterClass = 'spectreFormatter
nlCreateAmap = 't
simNetlistHier = t
All my bus signals looses their brackets (myBus_1 instead of myBus\<1\>).
Which option do i need to keep the bus format?
Best regards,
Christian
    Andrew Beckett over 7 years ago +1
    Christian, I split this post into a separate post as it was violating the forum guidelines - you had appended onto an old thread and it was really about a different topic than that thread (which was…
    Christian,
    I split this post into a separate post as it was violating the forum guidelines - you had appended onto an old thread and it was really about a different topic than that thread (which was about CDL netlisting, not spectre netlisting).
    See this article: How to get angular bracket netlisted in spectre netlist generated by SI or OSS based netlisting?
  • Lindi
    Lindi over 7 years ago in reply to Andrew Beckett
    Thanks for cleaning up the thread Slight smile
    That was exactly what i needed, thanks!
    Best regards,
    Christian
