  3. changing decending order in cadence schematic
  • Views 15069
SatendraMaurya
SatendraMaurya over 7 years ago
I want change the order on hierarchy descend. By default , it is schematic,symbol. I want to change it to schematic,extract,symbol.
I tried changing the viewNameLists using this cmd:
envSetVal("constraint" "viewNameList" 'string "schematic extracted_lvs  symbol")
But it did not help.
If I edit the Options->Editor ->ViewNameList, it works but only for the current schematic that's open. I want this for all.
Satendra
    Hi Satendra,
    You should be setting:
    envSetVal("schematic" "viewNameList" 'string "schematic extracted_lvs symbol")
    In other words, use "schematic" as the tool, not "constraint".
