  3. SPECTRE_RF_POSTLAYOUT_EAP Environment Variable
  • Views 15023
jslaton
jslaton over 7 years ago
In the "Getting The Most Out Of Spectre APS" application note, slide 11 recommends
"For RF analyses – If Spectre 17.1 ISR11 or newer, use HPA and setthe environment variable SPECTRE_RF_POSTLAYOUT_EAP to 1 – For older versions of Spectre, use Legacy-RF RCR"
I have confirmed that I am using Spectre 17.1 ISR11 (specifically that release); should I be able to query this environment variable from the CIW with getShellEnvVar("SPECTRE_RF_POSTLAYOUT_EAP")?
Also, is setShellEnvVar("SPECTRE_RF_POSTLAYOUT_EAP=1") in the CIW the correct way to set this?
Lastly, what does this environment variable do and is it a recommendation or required to use the new +postlayout with SpectreRF?
    Andrew Beckett over 7 years ago +1
    Actually, it's a mistake. If using that version of spectre and later, you do not need to set the environment variable. That was needed in Spectre versions before SPECTRE17.1 ISR11 (and then you just needed…
    Actually, it's a mistake. If using that version of spectre and later, you do not need to set the environment variable. That was needed in Spectre versions before SPECTRE17.1 ISR11 (and then you just needed the env var setting before spectre was launched). However, my recommendation would be to use SPECTRE17.1 ISR11 or later, or SPECTRE18.1
    The env var was needed to control access to a pre-release (early access partner) capability. It's now fully released, which is why we've removed the env var to control access.
  • jslaton
    jslaton over 7 years ago in reply to Andrew Beckett
    Thanks, Andrew!
