  3. The way to toggle between assembler and schematic
  • Views 15346
sjwprc
sjwprc over 7 years ago
Dear all,
    How to set bindkey being able to toggle between maestro tab and schematic tab in assembler ? Also similar feature to toggle between Outputs setup and results tab ? As shown in the pic following.
    By such way, you could save many time to manually switch between them.
BR
    There isn't really a function to switch between the maestro tab and schematic tab - for a start, you might have multiple schematics (for different tests). This would give  you all the windows which share the same session window (i.e. are in the same surrounding window) as the current window:
    setof(window hiGetWindowList() hiGetSessionWindow(window)==hiGetSessionWindow(hiGetCurrentWindow()))
    However, the simplest function to cycle through the tabs in a window is: hiLowerWindow(hiGetCurrentWindow())
    There is no function to switch between the Outputs Setup and Results tab within a Maestro view. In fact you'll see that when you do this, it doesn't even get logged in the CDS.log
