  3. Possible to avoid "Open Configuration or Top CellView" dialog...
  • Views 1222
Possible to avoid "Open Configuration or Top CellView" dialog when opening a config view?
dontpanic
dontpanic over 7 years ago
Hi! Is it possible to avoid the "Open Configuration or Top CellView" dialog when opening a config view from the library manager? Instead, I would want it to just open the config view.
(there is a seemingly-related solution here, but after closer inspection I believe it's not related to what I'm talking about)
Thanks and regards,
Jorge.
  • Dimitra Papazoglou
    Dimitra Papazoglou over 7 years ago +1
    Hi Jorge, Set the following to the .cdsinit: envSetVal("ddserv.he" "openConfig" 'cyclic "config") Then restart virtuoso. Regards, Dimitra
    Hi Jorge,
    Dimitra
  • dontpanic
    dontpanic over 7 years ago in reply to Dimitra Papazoglou
    Thanks Dimitra, that's exactly what I needed!
    Regards, Jorge.
