  3. ncvlog netlist generation
  • Subscribers 133
  • Views 14886
Nasser Arif
Nasser Arif over 7 years ago
HI,
I have schematic of transmitter, which has several blocks, which consist of functional view.
For one block (say BlockA), I have synthesized netlist with all cell definitions.
I am trying to generate the top level verilog netlist using ncvlog, I did below steps.
Created config view, and bind the  BlockA with symbol( My plan to pass the definition from out side)
and generate the netlist, it create the netlist but ignoring the blockA.
Could you please let me know if I am missing something here to netlist.
Nasser
    Nasser,
    It's not sufficient to just bind the view with symbol. You'd have to add symbol into the stop list - otherwise it just sees it as a hierarchical block with nothing in it, and so will get automatically omitted).
    Alternatively, you can use in the hierarchy editor, Right Mouse->Add Stop Point (you probably want to go over the header of the cell table and using the right mouse menu enable the "info" column to see the stop points). That will have the same effect.
