  3. Custom Independent Current Sources
  • Views 19112
Steval09
Steval09 over 7 years ago
Hello everyone,
I apologize in advance in case the question has already been answered
in a previous post (nonetheless, I would much appreciate a "pointer" to
the corresponding thread). Anyway, here's the problem:
I am relatively new (4 months) to Virtuoso (version 6.1.5-64b), ADE and Spectre and I would like to
custom-define and double-check with Spectre some independent current sources, namely by
using e.g. "iexp", "isin", or "ipulse" "ipwl" "ipwlf" etc, and perform an AC analysis with Spectre.
In particular it would be helpful to add e.g. simple current sources with the following behaviour in Laplace domain:
I(s)=A/(1+s*tau)
where "A" and "tau" are known.
Which is the best way to do it  by using the aforementioned sources?
Is there an easy way to achieve it with e.g. "iexp" or "isin" by setting the
corresponding damping factor (from e.g. tau=RC for the corresponding -1/tau pole)
and A (from the DC Current) directly inside the source? Are there any
step-by-step tutorials/guides? Do you recommend a different approach?
I tried by plugging both values e.g. in "isin", setting a "starting" frequency,
an arbitrary value for AC_magnitude (which should be "modulated" by
the damping factor) in the source panel, launching ADE and setting AC for a
target bandwidth, running Spectre, ... but I'm not getting the correct shape.
Some help panels are unfortunately not completely helpful, since they
mostly provide the same information stated in their corresponding
Property Panels for the (analog_lib) symbols, without further details.
Any help would be greatly appreciated
Best,
Stefano
    If you want to use a Laplace current controlled current source (or Laplace voltage controlled current source) use the scccs or svccs components. Type "spectre -h scccs" for info on the meaning of the parameters.
