  3. How get the "eventtime" variable calculated and used in...
  • Subscribers 133
  • Views 2671
How get the "eventtime" variable calculated and used in the sampled PAC analysis
groviere
groviere over 7 years ago
Hello.
I would like to use the "eventtime" variable in the calculator to perform a certain computation.
The "eventtime" variable I am talking about is the PAC sampling time, calculated when a certain condition is met. (In my case the condition is when a given net reaches vdd/2. This can be set-up in the PAC analysis form).
I can explicit access the computed value of "eventtime" in the Direct Plot-> PAC -> Variable Value (eventtime). In my case it's something like  4.50996n
However, as this value may change for different testing conditions, I would like to get it via variable evaluation. Something like: VAR("eventtime"), so I can use it in my calculator.
This what I currently have in the calculator:
value((v("/vop" ?result "pac-pac_cross") - v("/von" ?result "pac-pac_cross")) '"eventtime" '4.50996e-09)
This is what I would like to use instead.
value((v("/vop" ?result "pac-pac_cross") - v("/von" ?result "pac-pac_cross")) '"eventtime" VAR("eventtime"))
The latter expression is of course not working because VAR("eventtime") is not a correct expression.
The setup I am working with is: Virtuoso 6.1.7-64b and Spectre 18.1.0.169.isr2 64bit
Thank you for any help.
GR
    Andrew Beckett over 7 years ago +1
    You can use: sweepValues(v("/vop" ?result 'pac_sampled)) to get a list of the eventtime values. So if it's the first event, you'd use: car(sweepValues(v("/vop" ?result 'pac_sampled))) Note that…
    You can use:
    Note that I used the aliased result name here 'pac_sampled, but it would also work with "pac-pac_cross" too.
  • groviere
    groviere over 7 years ago in reply to Andrew Beckett
    Thank you very much Andrew.
    This solves my problem!
