  3. Assura QRC error in batch mode.
  • Views 16595
MedAn
MedAn over 7 years ago
Hi all!
Could you pls. help me to resolve some issue.
When I start Assura QRC form layout view - all works fine, but when I try to start the same in the batch mode,  I have following error:
SAVEDIR=`beginFlattenInputs`
beginFlattenInputs
export SAVEDIR
/bin/mv -f NET h_NET
flatnet -V -li -h '/' h_NET NET
Usage so far 0.00 user, 0.00 sys, 0.00 elapsed, 100284.0 kbytes
run out of memory or swap space for malloc(): Cannot allocate memory
ERROR (LBMISC-215023): run out of memory or swap space for malloc(): 0 bytes asked
ERROR (LBRCXM-609): Bad return status from RCX run. 0xff00
INFO (LBRCXM-709): ***** Quantus QRC terminated abnormally *****
Virtuoso version is: sub-version  IC6.1.7-64b.500.7
QRC version is: 14.2.2-s209
    I'm not sure how it can be different since the UI simply calls qrc in batch mode. The only thing I can think of is that you are accidentally running QRC in 32-bit mode when running from the command line? That should be apparent from the log file (you included so little above that I cannot tell).
    Also, why are you using such an old version of Quantus QRC? No need to use a version from 4-5 years ago...
  • MedAn
    MedAn over 7 years ago in reply to Andrew Beckett
    I'm using ccl file which was generated by cadence and simple try repeat it in the same environment: qrc -cmd <path_to_the_ccl_file> > myLog.log
    in head of the log file I have:
    Cadence Quantus QRC Etraction - 64-bit Parasitic Extractor - Version 14.2.2-s209 Tue Mar 24 21:31:22 PDT 2015.
    If it needed, I can attach the log file.
    Ok, I will try to use another version, which version you recommend?
    Andrew Beckett over 7 years ago in reply to MedAn
    In that case, I'm not sure what it is. The message says it failed to allocate memory - unclear why that should be any different with the 64-bit extractor from the command line than from the UI.
    I would suggest trying with the latest EXT182 hotfix or maybe EXT191 which is now released. If that doesn't work, please contact customer support as we're likely to need to see the testcase that has the problem.
  • MedAn
    Thx. to you Andrew, when I changed version on 17.1.1-s059 the problem has gone.
