  3. Spectre: TRAN results slightly differ according to which...
  • Views 15159
Spectre: TRAN results slightly differ according to which outputs are saved
dontpanic
dontpanic over 7 years ago
Hi! I noticed in the TRAN simulation of a 4GHz clock buffer that the calculated jitter at the output differs slightly depending on which outputs are saved. If I choose to save nothing but the output clock, I get ~17fs; if I save also a drain current of one of the devices in a diff pair in the DUT, I get ~18fs, and saving the currents of both devices gives ~19fs.
I double-checked the netlists produced in all cases, and indeed the only differences are the "save" statements.
What could be causing this? Reducing the maxstep from 1ps to 0.1ps seems to solve the problem, but I was expecting that for a given maxstep the results should be consistent irrespective to the outputs saved, shouldn't them?
I'm using Spectre 17.1.0.307.isr6 64b
Thanks and regards, Jorge.
    Andrew Beckett over 7 years ago +1
    Hi Jorge, Could you contact customer support over this? My guess is that the addition of the current saving is causing an iprobe to be inserted in the circuit (inside the simulator) which alters the…
    Hi Jorge,
    Could you contact customer support over this? My guess is that the addition of the current saving is causing an iprobe to be inserted in the circuit (inside the simulator) which alters the matrix and means you are getting a slightly different solution. I would expect that the solution is still within the simulator tolerances, but I can't really be sure without us seeing the example in more detail.
  • dontpanic
    dontpanic over 7 years ago in reply to Andrew Beckett
    OK Andrew, I'll file a case to have this checked further!
