  3. is it possible to extract the subcircuit names/models and...
  • Views 3934
is it possible to extract the subcircuit names/models and the associated pins from input.scs ?
marcelpreda
marcelpreda over 7 years ago
Hi there,
I have the netlist file input.scs , on top is spectre but may include hspice files.
I need a script/utility/command to extract from the entire hierarchy all the subcircuit definitions and the associated pin names of for each subcircuit.
The order of pin names should be the same as in netlist.
I assume that somehow spectre is doing all this stuff internally, is there any possibility to dump this info in a flat text file to be parsed after that?
Thank you,
Marcel
    Andrew Beckett over 7 years ago +1
    Hi Marcel, Add an info analysis such as this into the netlist: subcktInf info what=subckts where=file (you can do this in ADE via the Outputs->Save All form). This will produce a file called input…
    Hi Marcel,
    This will produce a file called input.info.subckts in the netlist directory (unless you specify a file to write it to) which includes the names of each subckt and the terminals (in order) for each subckt.
  • marcelpreda
    marcelpreda over 7 years ago in reply to Andrew Beckett
    Thanks a lot, it worked, with the note taht teh name of the file is actually subckts.info.subckts .
    I have next question: for some subcircuits there is no info about teh parameters and pins (they are empty strings).
    My guess is that this is happening for the subcircuits which are not used in my design, but are defined in the model files. Is that true?
    Also, is there any documentation about the format of this file, or a skill API to interrogate this database?
    Best Regards,
    Marcel
    Andrew Beckett over 7 years ago in reply to marcelpreda
    Hi Marcel,
    The subckts.info.subckts is a "PSF" database that is saved into the psf directory if you have where=rawfile specified - there's an entry on the Outputs->Save All form which saves that by default. If you want to process the PSF results, you can simply do:
    selectResult('subckts) ; to avoid having to add ?results 'subckts on the end of the outputs() or pv() functions below:
    foreach(subckt outputs()
      terminals=pv(subckt "subckt_terminals")
      params=pv(subckt "subckt_params")
      unless(blankstrp(terminals)
        printf("%s : %s : %s\n" subckt terminals params)
    You're right - unused subckts (e.g. from model files) are output with an empty terminal list.
  • marcelpreda
    Thanks again.
    You are very kind, not too much work left for me: I just had to copy->paste :)
    Best Regards,
    Marcel
