  3. how to setup connectivity between layout and schematic
  • Views 18425
Amit yadav
Amit yadav over 7 years ago
Hi
How to setup connectivity between layout and schematic?
How i can know the net names in layout ?
i m using Virtuoso 6.1
Regards
Amit
  • skillUser
    skillUser over 7 years ago
    Hi Amit,
    Use Virtuoso Layout Suite XL (sometimes called "VXL" or "VLS-XL") - the layout is 'generated' from the schematic which maps devices, pins and connectivity to the layout.  If you have an existing layout then you would need to make it 'XL' compliant by establishing device correspondence (and also device terminal correspondence / connectivity) between the layout and the schematic.  Sounds like you either need training, or you need to read the documentation and/or look at the available resources such as videos and Rapid Adoption Kits.
    Best regards,
    Lawrence.
