  3. Fix "tool tip" colors in GNOME
  • Subscribers 130
  • Views 2672
dontpanic
dontpanic over 6 years ago
Hi! I'd like to solve the known problem of barely-readable Virtuoso tooltip colors (white text in pink background) in GNOME. I repeatedly found the solution to fix it in KDE, but I was unable to find an equivalent procedure in GNOME. Has anybody been able to achieve this?
Thanks and regards, Jorge.
    Hi Jorge,
    I found two bits of info related to this. Not sure if either fix the problem reliably because I didn't try it myself.
    The first is another article: Toolbar tooltip (or mouseover popup message) fonts are hard to read"
    The second was a case which had this summary:
    I solved problem with white-on-black tooltips with 4 gtkrc files:
    1. ~/.config/gtk-3.0/gtk.css
    /* tooltips */
    @define-color tooltip_bg_color #ffffaf;
    @define-color tooltip_fg_color #000000;
    2. ~/.config/gtk-3.0/settings.ini
    [Settings]
    gtk-color-scheme = "tooltip_bg_color:#ffffaf\ntooltip_fg_color:#000000"
    3. ~/.gtkrc-2.0
    include ".gtkrc-2.0-gnome-color-chooser"
    4. ~/.gtkrc-2.0-gnome-color-chooser
    style "gnome-color-chooser-tooltips"
    bg[NORMAL] = "#FFFFAF"
    fg[NORMAL] = "#000000"
    widget "gtk-tooltip*" style "gnome-color-chooser-tooltips"
    http://askubuntu.com/questions/70599/how-to-change-tooltip-background-color-in-unity
    You can rename the /home/user/.config folder to resolve the issue.
  • dontpanic
    dontpanic over 6 years ago in reply to Andrew Beckett
    Hi Andrew; removing the  "$HOME/.config/Trolltech.conf" file solved the problem! It changed the tooltip font color to black, which has good contrast against the pink background.
    Thanks so much for your help!
    Regards, Jorge.
