  3. Plotting transistor parameters in a temperature sweep
  • Views 18273
CADcasualty
CADcasualty over 7 years ago
I'm doing a temperature sweep using:
analysis('dc ?saveOppoint t ?param "temp" ?start "-40" ?stop "120" ?step "20" )
Aside from the usual voltages and currents, is it possible to also plot an operating point aspect of a device e.g. mn1's threshold vth or transconductance gm?
    Andrew Beckett over 7 years ago +1
    Yes, add: saveOpPoint( "/I7/M1" ?operatingPoints "gm vth" ) This corresponds to the Outputs->To be saved->Select OP Parameters entry in ADE L. Having done that, you can then plot OS("/I7/M1" "gm")…
    Yes, add:
    This corresponds to the Outputs->To be saved->Select OP Parameters entry in ADE L. Having done that, you can then plot OS("/I7/M1" "gm") or using getData("I7.M1:gm" ?result 'dc)  - unfortunately for the latter you have to use the netlist name for the component.
  • CADcasualty
    That works perfectly! Thanks.
    You know - I'm hoping that people spending their vacations helping me out is a trend that catches on. The world needs more people like that (until I retire) ;-).
