  3. PVS Rule writing
  • Views 17236
PVS Rule writing
Pranay99
Pranay99 over 7 years ago
How to check the length and perimeter of all the nodes by writing  PVS rule.
Thank you
Pranay
  • Quek
    Quek over 7 years ago in reply to Pranay99 +1
    Hi Pranay Sorry to keep you waiting. Here are my comments: a. I have checked internally and confirmed that measurement of total net length cannot be easily done. This is because of the available cmds and…
  • Quek
    Hi Pranay
    Perhaps this is what you need:
    rule test {
       path_length myLayer -lt 123
       perimeter myLayer -lt 123
    Best regards
    Quek
  • Pranay99
    Pranay99 over 7 years ago in reply to Quek
    Thanks Quek, but I am not looking for perimeter or length of any particular layer.
    What exactly I want is to check the  perimeter and length of all the nets which means it may contain different metal layer based on connectivity on that net.
    It will be very helpful if you can guide me on this.
  • Pranay99
    Hi All,
     How to write PVS rules to  check the  perimeter of all the nets individually? I don't want to check perimeter of a particular layer.
    For example for routing connection M1, Via1, M2, Via2, M3, Via3 M4 are used. Now I want to highlight all the connection which have perimeter more than 5micron. Perimeter value includes  M1, Via1, M2, Via2, M3, Via3, M4  as single layer depending upon connectivity of the connection.
    Thank you in advance.
    Regards
    Pranay
  • Quek
    Hi Pranay
    a. I have checked internally and confirmed that measurement of total net length cannot be easily done. This is because of the available cmds and also because of the definition of net length itself. E.g. a net may have multiple branches. How do we define the length for such a case? If the longest branch is to be used, how to filter the shapes for the other branches?
    b. For perimeter, perhaps you can try the following:
    rule checkPerim {
       antenna m1 m2 m3 -gt 0 -expr "perimeter(m1)+perimeter(m2)+perimeter(m3)" -rdb "perim.rdb"
    At the end of the DRC run, egrep for "VALUE" in perim.rdb file:
    terminal> egrep "VALUE" perim.rdb
    === perim.rdb ===
    test_net 2000
    checkPerim:antLay_1
    1 1 3 Mar 17 11:25:48 2019
    ANTENNA -gt 0.000000 m1 m2 m3 -rdb perim.rdb checkPerim:antLay
    CELL=test_net FPC=1 NET=1 NETNAME=myNet2 VALUE=7.960000
    m1 AREA= PERIMETER=1.580000 COUNT= DBCOUNT=1
    There will be some inaccuracies because the ends of each shape might be double counted. You can try to do some more layer processing to see if this can be resolved.
    Best regards
    Quek
  • Pranay99
    Hi Quek,
    Thank you very much, for the help.
    Is working properly as you suggested.
    Best regards
    Pranay
