  3. QRC: extraction fails due to ports names including the ...
  • Views 2411
QRC: extraction fails due to ports names including the "+" character
dontpanic
dontpanic over 7 years ago
Hi! The QRC extraction of various cells is failing due to them having port names that use the "+" character. For example, In the QRC log file I get:
+ERROR (LBMISC-215479): at "agds2rcx": syntax error in file /path/to/my/svdb/my_cellname.ports because of an invalid character '+' at line 12
(and in the my_cellname.ports file I see that line corresponds to the entry associated to a port named "clock_latch_N+1").
Is is possible to make PVS/QRC support these port names with the "+" character? We have many cells affected by this, so we'd like to avoid the pain/risk of changing them now (tapeout time).
Thanks and regards, Jorge.
  • Quek
    Quek over 7 years ago +1
    Hi Jorge "+" is not a legal character in spice so even if the extraction succeeds, the generated spice netlist may also create error during simulation. It would be best for you to rename the port. E.g…
  • Quek
    Hi Jorge
    "+" is not a legal character in spice so even if the extraction succeeds, the generated spice netlist may also create error during simulation. It would be best for you to rename the port. E.g. clock_latch_Np1
    Best regards
    Quek
  • dontpanic
    dontpanic over 7 years ago in reply to Quek
    Thanks for your reply, Quek. We normally use the extracted view as output for the extraction (not spice netlists), so in this particular case that probably shouldn't be really be a limitation.
    But if there's just no workaround for this issue, I guess I'll have no other choice than renaming all those ports!
