  3. Quantus: warning regarding separate field solver techfile...
  • Views 15160
Quantus: warning regarding separate field solver techfile with MEOL stack description
dontpanic
dontpanic over 7 years ago
Hi! I am getting the following warning when performing Quantus extractions with the FS extraction mode:
WARNING (NEBULAM-135092): Design is using device stack extraction in 'TSMC finfet' node. Foundry is supposed to provide separate field solver techfile with MEOL stack description. With current techfile you are not going to get sign-off certified accuracy for nets connected to MEOL devices. If you do have FS technology file and still see this warning request Cadence support to recover accuracy.
Do I need to have some additional decks installed in order to use the FS extraction mode? I am using Quantus 18.2.1-s210 on TSMC 16FF+ PDK.
Thanks and regards, Jorge.
  • Quek
    Quek over 7 years ago +1
    Hi Jorge There should be a file named "_qrcfs_profile" in the QTS tech directory. You can contact TSMC to get the file. Best regards Quek
  • Quek
    Hi Jorge
    Best regards
    Quek
  • dontpanic
    dontpanic over 7 years ago in reply to Quek
    Thanks for the info, Quek; I'll contact the foundry to get the required file!
