  3. Running Cadence Virtuoso in command line without GUI
  • Views 35452
Naveen16
Naveen16 over 7 years ago
 Hi, I have a question on how to perform SKILL functions in command line mode.
What I want to do is to
(1) start cadence with no GUI.
(2) perform a series of SKILL function (defined in a do file) such as adding tech file to a library, adding layers.
(3) quit cadence
Heard that virtuoso -nograph option would work but it looks like I need to setup some unix environment variables to make that command work. Not sure what environment variable should I be adding in .kschrc files. Can anyone help?
Thanks.
    I don't see why you should need to set up any UNIX environment variables to run "virtuoso -nograph". Essentially what you are trying to do could be done with "virtuoso -nograph -restore code.il". Potentially you could use the lighter "dbAccess" (e.g. dbAccess -load code.il).
  • Naveen16
    Naveen16 over 7 years ago in reply to Andrew Beckett
    Thank You Andrew. It did work for me.
    I am able to run the virtuoso in no GUI mode and I am trying to load a skill file with some skill commands for loading files and attaching techfile to libraries
    I am using the techBindTechFile function in the SKILL file.
    techBindTechFile(ddCreateLib("MANUAL") "Techlib" "tech.db" t)
    techBindTechFile(ddGetObj("PCELLS") "Techlib" "tech.db" t)
    exit
    But I am getting the warnings as below,
    \w *WARNING* (TECH-2000010): techBindTechFile: nil is an invalid ID. The valid ID is dbCellViewId or ddId for a cell or library. Specify the valid ID and rerun the function.
    But if I load the same file after opening the cadence with GUI it attaches the techfile to library. So I am wandering what differently should I be doing for attaching the tech file in no GUI mode.?
    Any advice??
    Naveen
    Andrew Beckett over 7 years ago in reply to Naveen16
    Hi Naveen,
    The most likely explanation is that you're running the "virtuoso -nograph" session in the wrong working directory, and you don't have permission to create the library in that directory - for the first call. For the second one, the library presumably is not in the cds.lib in that directory.
    Perhaps you should get your code to print out:
    printf("WORKINGDIR=%s\n" getWorkingDir())
    printf("KNOWN LIBRARIES: %L\n" ddGetLibList()~>name)
  • Purge2343
    Purge2343 over 6 years ago in reply to Andrew Beckett
    I tried the virtuoso -nograph -restore code.il command
    it shows me the following error
    -nograph: Command not found.
    Andrew Beckett over 6 years ago in reply to Purge2343
    The only way I can get this is if I put "-nograph" on a separate line. Maybe you have a wrapper script around virtuoso so what you're running is not actually the virtuoso from the Cadence installation?
    Perhaps you should check where virtuoso using "which virtuoso" and see whether there's a wrapper in the way.
