  3. Installing the license file
  • Views 14914
magti
magti over 7 years ago
The following products are paid for:
#INSTALLSCAPE PRODUCT "PALT812" "PALT812: Liberate AMS Client"
#INSTALLSCAPE PRODUCT "PALT810" "PALT810: Liberate AMS Server"
#INSTALLSCAPE PRODUCT "PALT411" "PALT411: Liberate MX Client"
#INSTALLSCAPE PRODUCT "PALT410" "PALT410: Liberate MX Server"
#INSTALLSCAPE PRODUCT "PALT211" "PALT211: Liberate Variety Client"
#INSTALLSCAPE PRODUCT "PALT210" "PALT210: Liberate Variety Server"
#INSTALLSCAPE PRODUCT "P95310" "P95310: Virtuoso(R) Layout Suite XL"
#INSTALLSCAPE PRODUCT "P90005" "P90005: Spectre Multi-Mode Simulation with AMS"
#INSTALLSCAPE PRODUCT "P95210" "P95210: Virtuoso(R) Analog Design Environment XL"
#INSTALLSCAPE PRODUCT "P95115" "P95115: Virtuoso(R) Schematic Editor XL"
#INSTALLSCAPE SOURCE "is/LIBERATE191/lnx86/Base"
"Base LIBERATE191 LINUX RHEL 6;RHEL 7;SLES 11;SLES 12 LIBERATE19.1.0 Release"
"Version Base LIBERATE191 LINUX RHEL 6;RHEL 7;SLES 11;SLES 12 LIBERATE19.1.0 Release"
#INSTALLSCAPE SOURCE "is/IC618/lnx86/Base"
"Base IC618 LINUX RHEL 6;RHEL 7;SLES 11;SLES 12 IC6.1.8.83 Release"
"Version Base IC618 LINUX RHEL 6;RHEL 7;SLES 11;SLES 12 IC6.1.8.83 Release"
#INSTALLSCAPE SOURCE "is/SPECTRE181/lnx86/Base" "Base SPECTRE181 LINUX RHEL 6;RHEL 7;SLES 11;SLES 12;Ubuntu 14 18.10.077 Release"
"Version Base SPECTRE181 LINUX RHEL 6;RHEL 7;SLES 11;SLES 12;Ubuntu 14 18.10.077 Release"
All the necessary information in the key file entered.
I launch the license server
/SOFTWARE/cadence617/LIBERATE171/tools/bin/lmgrd -c /SOFTWARE/licenses/srv-work3.ti/license.dat -l /var/log/cadence/libarate.log
Error in the log file
12:10:52 (lmgrd) FlexNet Licensing (v11.13.1.3 build 176483 i86_lsb) started on srv-work3.ti (linux) (2/28/2019)
12:10:52 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved.
12:10:52 (lmgrd) World Wide Web: http://www.flexerasoftware.com
12:10:52 (lmgrd) License file(s): /SOFTWARE/licenses/srv-work3.ti/license.dat
12:10:52 (lmgrd) lmgrd tcp-port 5280
12:10:52 (lmgrd) (@lmgrd-SLOG@) ===============================================
12:10:52 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
12:10:52 (lmgrd) (@lmgrd-SLOG@) Start-Date: Thu Feb 28 2019 12:10:52 MSK
12:10:52 (lmgrd) (@lmgrd-SLOG@) PID: 20107
12:10:52 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.3 build 176483 i86_lsb ( build 176483 (ipv6))
12:10:52 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
12:10:52 (lmgrd) (@lmgrd-SLOG@) Listening port: 5280
12:10:52 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
12:10:52 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
12:10:52 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c /SOFTWARE/licenses/srv-work3.ti/license.dat -l /var/log/cadence/libarate.log
12:10:52 (lmgrd) (@lmgrd-SLOG@) License file(s) used: /SOFTWARE/licenses/srv-work3.ti/license.dat
12:10:52 (lmgrd) Starting vendor daemons ...
12:10:52 (lmgrd) Started cdslmd (internet tcp_port 35601 pid 24235)
12:10:52 (cdslmd) FlexNet Licensing version v11.13.1.3 build 176483 i86_lsb
CADENCE_INFO_MSG: Cadence kit version: 12.07-p001
12:10:52 (cdslmd) SLOG: Summary LOG statistics is enabled.
12:10:52 (cdslmd) SLOG: FNPLS-INTERNAL-CKPT1
12:10:53 (cdslmd) SLOG: VM Status: 0
12:10:53 (cdslmd) SLOG: FNPLS-INTERNAL-CKPT2
12:10:53 (cdslmd) License server system started on srv-work3.ti
12:10:53 (cdslmd) No features to serve, exiting
12:10:53 (cdslmd) EXITING DUE TO SIGNAL 36 Exit reason 4
12:10:53 (lmgrd) cdslmd exited with status 36 (No features to serve)
12:10:53 (lmgrd) cdslmd daemon found no features. Please correct
12:10:53 (lmgrd) license file and re-start daemons.
12:10:53 (lmgrd)
12:10:53 (lmgrd) This may be due to the fact that you are using
12:10:53 (lmgrd) a different license file from the one you expect.
12:10:53 (lmgrd) Check to make sure that:
12:10:53 (lmgrd) /SOFTWARE/licenses/srv-work3.ti/license.dat
12:10:53 (lmgrd) is the license file you want to use.
12:10:53 (lmgrd)
12:11:35 (lmgrd) -----------------------------------------------
12:11:35 (lmgrd) Please Note:
12:11:35 (lmgrd)
12:11:35 (lmgrd) This log is intended for debug purposes only.
12:11:35 (lmgrd) In order to capture accurate license
12:11:35 (lmgrd) usage data into an organized repository,
12:11:35 (lmgrd) please enable report logging. Use Flexera Software LLC's
12:11:35 (lmgrd) software license administration solution,
12:11:35 (lmgrd) FlexNet Manager, to readily gain visibility
12:11:35 (lmgrd) into license usage data and to create
12:11:35 (lmgrd) insightful reports on critical information like
12:11:35 (lmgrd) license availability and usage. FlexNet Manager
12:11:35 (lmgrd) can be fully automated to run these reports on
12:11:35 (lmgrd) schedule and can be used to track license
12:11:35 (lmgrd) servers and usage across a heterogeneous
12:11:35 (lmgrd) network of servers including Windows NT, Linux
12:11:35 (lmgrd) and UNIX. Contact Flexera Software LLC at
12:11:35 (lmgrd) www.flexerasoftware.com for more details on how to
12:11:35 (lmgrd) obtain an evaluation copy of FlexNet Manager
12:11:35 (lmgrd) for your enterprise.
12:11:35 (lmgrd)
Help fix the error
  • Marc Heise
    Marc Heise over 7 years ago
    if this is kind of urgent I would advice to contact customer support and open a ticket. Exchanging detailed license and IT information over a public forum might not be a good idea.
    The machine you start the license server on is the right one with  the hostid  in the license file ? ( Don't change it in the license file)
    Again, please open a ticket and let the dedicated Cadence AE sort it out.
    Marc
