  3. fsdb to pwl
  • Views 20806
fsdb to pwl
KOTB
KOTB over 7 years ago
If Ihave 'fsdb' file which represents the simulations results of a simulation (waveforms), is there a way to transform it into pwl (piece wise linear) signals that I can use as stimulis ?
Kotb
    Hi Kotb,
    You can open the FSDB file in ViVA and then in the results browser do right-mouse->Export over the signal you wish to convert to PWL and export it in "SPECTRE" format. This will create a PWL file that can be read with vpwlf from analogLib or vsource specifying that the PWL data is coming from a file.
  • KOTB
    KOTB over 7 years ago in reply to Andrew Beckett
    Thank you Andrew, it works perfectly
    kotb
  • SatendraMaurya
    SatendraMaurya over 6 years ago in reply to Andrew Beckett
    Is there a automated way to do this? I have bunch of signal to convert to PWL and also across lots of corners?
    Satendra
    Andrew Beckett over 6 years ago in reply to SatendraMaurya
    I didn't try doing this across corners, but you're going to have to create individual files for each corner anyway. So you'd do:
    pathToResults="/export/home/username/tools/spectre/adc.raw"
    listOfSignals=list("o1" "o2" "o3" "o4" "o5" "o6")
    database="tran-tran"
    outputDir="./adc.pwl"
    rdbLoadResults("unbound" pathToResults)
    rdbWriteToFormat("unbound" outputDir "SPECTRE" list(list(pathToResults list(list(database listOfSignals)))))
    Unfortunately there's a limitation now that the results browser has to be opened and displayed for the export to happen (otherwise it just returns t but doesn't actually write the data). There's a CCR for this, CCR 1054798.
